1993 Jeep Grand Cherokee - Help getting started
The engine won’t start. It turns over with the starter. The fuel rail has gas as soon as you turn on the key. {t had a broken spark plug wire which we replaced. How do you check the air sensors in the exhaust and intack?
Just because there is gas at the fuel rail, doesn’t mean the injectors are working.
Try starting it using starting fluid to see if it’s a lack of spark or fuel problem.
