I have three problems on my truck. The front windows on the truck don’t go down, but there is nothing wrong with the window motor. My front doors on my truck don’t lock. On the driver side of the door, it won’t open from the inside. What can i do to fix these problems?
Do you have the correct ground/power signals present at the window motors when the switch is pressed?
I conclude we are speaking about power locks,inop from master switch?,key fob,outside lock cylinder? Fuse,circuit breaker check,switch.Is Explorer 4 door? do other locks work?
I conclude door is unlocked when you try to open from inside,can you remove inside pull handel and pull on the rod to open the door? (if yes,you may just need to bend the rod a little,this shortens it,we did this for GM many times)
