Dies intermitly. Not fuel pump but electrical problem. It does it if engine is hot or cold. sometimes it starts back up. Or sometimes have to wait 5 or 10 minutes. Help Please
If the problem is due to the fuel pump not getting voltage voltage to it when this happens, I then suggest you check the fuel pump relay for a problem as the first step to try and solve this problem.
Several of the Dodge relays, in the relay box under the hood, are the same type of relay. Therefore, you can swap the horn relay with the F/P relay. You can, also, swap the ASD relay (which might control the fuel pump) the same way.
