I just purchased the truck 2 weeks ago. The radio was not working. I found out it had been unplugged. The problem is that there are 2 connectors that seems to be “female.” Therefore, they cannot connect together. I cant find any other connectors so I am assuming the adapter is missing. Does anyone know where or how I can find a way to make the radio work? Its not so important that the radio work since I am Deaf but I do need the clock. Thanks!
If the original radio is still there you should be able to find what you need in a junk yard.
If it’s an aftermarket radio you could try Crutchfield.com and see if they have an adapter.
Or you could buy a small, battery operated clock and stick it to the dashboard.
How about a wristwatch?
