put new clutch plate in.hydralic clutch.no clutch pedal-tried bleeding still no clutch.what to do next.any advice u got will be helpful
Have someone look for action at the slave cylinder as someone pushes the pedal. If no action, replace the master and slave together. Should fix the problem.
If the slave moves freely, then something is wrong in the installation of the clutch plates. Did you replace the throwout bearing and clutch disk? Also the pilot bushing?
