I had a 89 Plymouth Acclaim and had the same problem as the caller. Thought it was the right wheel bearing too and after having it replaced, still no luck. Found it was the right upper motor mount after a bit of frustration. Basically I got the care moving, shut off the engine and turned left. No noise. Turns out the mount was broken and when you turn left, the engine leaned to the right and the pulley was hitting the side.
Related topics
| Noise when turning Left on 89' Dodge Omni April 20 2013 | 0 | 459 | April 25, 2013 | |
| 2002 Dodge Neon - Strange Sounds | 4 | 845 | October 30, 2013 | |
| Engine moves when turning left | 2 | 655 | April 2, 2020 | |
| Odd Sound on Fast Left Turn | 0 | 288 | November 5, 2010 | |
| Motor Mounts, which one? | 5 | 602 | August 6, 2012 |
