I have an '09 Camry and for the last few months have been hearing a metal popping sound in the rear wheel area when I go over a bump or pothole unevenly or backout of a driveway at an angle to go onto the street. The sound does not occur when the wheels when they are even, only when the rear right wheel is “lower” than the left. It has not been in any accidents and there was no event that preceded this popping. I took it to the dealership but they were unable to replicate the issue but it happens no matter who drives the car (my husband or myself) and it is likely that the service guys didn’t go over any bumps/curbs/potholes unevenly to hear the sound. Any idea of what this is or if this is in need of getting fixed? They check the axles and said everything was good with the car but it is still popping and driving me nuts.
Current suggestions:
• cracked bearing race. It could be another problem entirely having to do with the suspension mounts or axle mounts but let’s hope these new mechanics will figure it out.
• problem with a wheel bearing
• struts and suspension components
• bushings and parts
• loose upper strut center nut or from loose upper strut mounting nuts
UPDATE: I took it back to a shop but they are thinking the sound is actually coming from the body near the roofing area in the right rear portion of the car. They seem to think based on the sound (metal popping only when that wheel is lower (like coming out of a driveway angled, or going over a pothole)) that it is the metal body but it would cost and arm and a leg to get in to even find out what it was. They assured me that it wasn’t impacting the safety of the body and is just a funky sound. The sound is much louder in the car than outside which I think kind of supports their theory. Any thoughts? Are they right and it won’t impact the safety?
