-check engine light- turned off - 91000 Miles, 2008- Saturn Aura
What are the codes and symptoms you are having with the vehicle??
If your check engine light is no longer illuminated ( turned off as you said) it means one of two reasons:.
Engine error has been corrected
Or
The light has burned out
That seems like a good thing. Is there an associated problem you are trying to solve?
