Hello everyone, I got a feeling that my shifter cable is on it’s way out but I want second opinions before I take my car to have the transmission rebuilt.
So the main issue with my g5 is that sometimes the car will drive forward/reverse and at random, you’ll hear very loud and fast clank/clunking noises which the car would slow to a stop; the RPM needle still moves at a steady and normal pace when driving/reversing. The problem doesn’t happen in Neutral unless you change from drive/reverse. I went to check out to make sure it wasn’t something with the CV joint I replaced and also noticed that when I had the car in Park it moved backwards a way on a flat surface.
The check engine light also does not appear.
Any thoughts on what the problem could be?
