05 Dodge Ram 2500 Steering problem
After recently using our 2500 to haul the horses and having to so some ‘heavy’ steering to back it up through some tight turns, a problem arose.
When driving at any speed, it seems to wander a bit more than usual. Worse though, it seems to not want to re-center when coming out of a turn. You have to actually ‘steer’ it back straight. PS fluid is fine. Any ideas?
Thanks!
Yea, get it to a good suspension shop. They should be able to find the problem quickly. I suspect a damaged or worn part.
