I would love some help with this. The driver’s side floorboard of my 03 Sebring LXI is always wet. The passenger side is completely dry. It has nothing to do with rain…even during a drought, its wet.
HELP!!
Thanks!
I would look for a leaking A/C due likely to a clogged drain.
Thanks Joseph~
Actually I was told it probably wasn’t the A/C because its on the driver’s side.
I appreciate your quick reply.
I would remove the carpeting so that will thoroughly dry out. Otherwise, you run the risk of rusting out the floorboard. While the carpet is out, you may be able to see where the moisture is coming from that is causing the dampness of the carpet.
When you run the AC in park, does water drain out onto the ground?
