I replaced the a/c relay with success on my '03 Camry, but the idle speed has decreased significantly and the engine stalls. When I changed the relay, I disconnected the negative battery terminal during the relay change and reconnected once the new relay was in place. The low idle/stalling problem coincided with the a/c relay change. Any suggestions? BTW - the battery tested fine. I also put the old relay back with the same problem.
Related topics
| Car Is Stalling Out | 2 | 395 | July 3, 2008 | |
| Dead Battery - no idle | 5 | 786 | September 18, 2008 | |
| Car stalls in neutral | 1 | 795 | August 16, 2007 | |
| 2003 Camry Electrical Enigma | 2 | 503 | May 11, 2013 | |
| 1999 Camary + low idle + stalling | 4 | 1037 | April 14, 2014 |
