My 85,000 mile van’s fan only works in high. So it is either no heat on or on high. Anybody had this problem?
The blower motor resistor pack needs to be replaced. Fairly common and and fairly simple.
Thanks NYBo I will give this a try!
You’re welcome!
One more thing: If the new resistor pack meets an untimely end, the blower motor is failing and drawing too much current.
