'01 town and country air condition
Our 2001 Chrysler town and country has had nothing but A/C trouble since we bought it.
Current problem is that the rear and passenger air blows cold while the driver side blows hot. Any suggestions
It sounds like the drivers’s side has a vent door problem. They direct the hot and cold air flow. Your AC is working but you just aren’t getting the correct air flow from one of the doors.
sounds like it could be the blend doors.or you are low on freon.put your heat on both sides to see if you are getting the same hot air flow out of all the vents.
You may be able to reset the climate control system using one of the alternative methods listed here:
http://www.allpar.com/fix/codes-climate.html
