Join the Car Talk Community!
Discussion Rules
Sign In Register
1999 ford windstar rapid blinking anti theft light
my windstar blew fuse #16. replaced soon. blew again, replaced again. now theft light blinks rapidly and won't even crank over. left switch on long enough to get a code reading from the light, it comes up to # 15. can anybody help with this problem? thanks MOPAR 64
«1
Comments
  • Mopar 64,
    Fuse 16 is for the Instrument Cluster and the REM module.. The cluster is part of the PATs system (Passive Antitheft). Because the Cluster is offline, the security handshake cannot be made between the PCM and Cluster, preventing the vehicle from starting.
    The REM module controls things like the rear tail lamps, Power sliding doors, rear locks, liftgate, aux climate control. Shut those systems off, replace the fuse, and see if the fuse blows again (without activating those systems).. If ok, activate each system one at time and look to see if and when the fuse blows... If the fuse blows when the rear climate system is engaged, then you know where you need to start looking for shorts. If the fuse blows immediately, then you will need to isolate the REM and Cluster, and retry.
    Not sure how deep you want to get with this issue yourself. You will have some disassembly to do to begin isolating the circuits.
  • edited March 2013
    jgree142
    I found this on the internet, I made this repair fuse no longer blows
    Although the fuse was blowing (not instantly) the car still started and ran but when you shut it off head lights would come on. Light started rapidly blinking after i unhooked battery cables and put a amp gauge in line between cable and pos post.to see with switch off how many amps were being pulled (because this is a hot line all time) about 10amp for a short time then dropped to 0. hooked cables back up and this is the problem that occurred (the not starting)
    There is a technical service bulletin from Ford and here is the fix. Fuse # 16 is blown therefore the ignition off signal is not being sent to the front end module. Pin # 11 (Windstar wiring diagram) on wiring harness C-239 is shorted. The diagram will show you where the wire goes to a front harness on the fuse box from the back of the instrument cluster. I simply cut the wire at both ends and ran a new wire. I have a 1999 Windstar- hope this helps. I spent 2 weekends looking for this and finally figured it out- cost nothing to fix and only took about 30 minutes. It did take me about 3 hours to put the car back together though.
  • Good Job
  • jgree142
    thanks but not such a good job now it wont start is there any reason that i would be getting a code 15 from the theft light could i of erased the memory in any way? thanks again
  • Chances are that the main power wire for the REM that runs under the carpeting front to rear is chaffed. I can't tell you how many I've repaired due to this issue.
  • pete peters
    thanks i will defintley check that next, is that under drivers side or passenger side ?
  • The power wire running the REM is white/yellow. Pin 10 at connector 219 fuse panel. On the other end it will be pin 3 at connector 343 at the REM. instead of trying to peel back carpeting and trying to locate the problem area, I will cut the wire at both ends and run a new one.
  • pete peters
    sorry it took so long to respond, well there was no power getting to the rem so i ran a tempoary fused wire from battery and it still does the same thing what would you think i should do next besides scrap it. thanks
  • I am not sure what is happening but I would try doing as @pete peters suggested.
  • I am assuming that the PATs (antitheft) lamp is still flashing? I understand that you ran a new pwr circuit from the Battery directly to the REM.... I can only assume that the new installed fuse is good. What is the condition of fuse 16? (If you only ran the power to the REM, the cluster would still be on fuse 16) If fuse 16 is blown, the cluster logic will not function properly and antitheft will be affected.
    Let us know the states of fuse16 and the fuse to the REM.
    Just a little more work and I think you got it. Let us know
