- Listen
- Our Show
- Car Info
- Buying
- Owner Reviews
- Tom and Ray's Reviews
- Research a Car
- Find a new or used car
- Cars We Hate the Most
- Secret Tricks of Car Salesmen
- Hybrid Vehicles
- Calculator
- New Car Incentives
- More…
- Owning
- Post a Review of Your Car
- Tom and Ray Explain Maintenance
- Check Safety Recalls
- Want To Do It Yourself?
- How To Keep Your Car Running Forever
- Premium vs. Regular
- Change a Flat
- Car Cleaning Tips from a Pro
- Official Car Talk Guide to Jump-Starting Your Car
- Guide to Better Fuel Economy
- More…
- Cars.com Content
- Mechanics Files
- Blogs
- Community
- Fun Stuff
- Store
- Contact
Comments
If that's not the case, I suggest you consult a service manual for the vehicle, and see what it says about sunroof operation, or lack thereof.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeEd B.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeWhen I removed the headliner I could see a red plastic turn as I try to open or close the sunroof. I suspected that I could use that to manully crank it close but was not sure. There is an opening in the center which looks like an allen wrench could fit.
Should I disengage the motor first before attempting this?
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeNote: This is assuming that nothing mechanical is broken the roof is not off track.
Tools used: 1 T25 screwdriver and lots of patience.
1. Checked the tracks if anything was blocking them. I did not find any.
2. Disconnect the wire connected to the reading lamps on the rear view mirror.
3. Pull out the 2 plastic retainers holding the headliner. 1 on each side of the switch assembly and I managed to break one in the process.
4. Use the T25 screwdriver to remove the 3 screws holding up the 2 sun visors.
5. Peal off the rubber that holds the headliner on the front edge of the roof openning and pull down on the headliner. You should see the motor/actuator assembly.
6. Remove the 3 T25 screws holding up the motor assembly.
7. Pull down the motor assembly and you should see some gears on the other side. The plastice gears seems to be a counter next to the sensor that tells the motor when to stop.
8. With the motor disengaged, press the switch to close position untill the motor stops.
9. Now, press the motor once and it should turn on for a few sec. That should be the vent position on the sunroof. Press it again and the motor should turn all the way to the open position.
10. Now push the sunroof all the way back untill it stops.
11. Re-install the motor assembly and try if it closes all the way. You migh have to do it a few times. It worked the first time for me..
And now it works again.
Thank you all for responding and all your tips helped...=)
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeMy car has an allen wrench specifically for this purpose, and an access port near the rear window. Luckily, I've never had to use either of them.
- Spam
- Abuse
- Troll
- Spam
- Abuse
- Troll
