Join the Car Talk Community!
Discussion Rules
Sign In Register
All dashboard gauges not working
I have a 2002 Z3 and all the gauges have stopped working. The onboard computer still works, radio, windows. No turn signals, odometer, tach, speedometer, temperature or fuel. Is this a fuse or bigger problem?
Comments
  • edited July 2010
    If your gauges are LCD, I would check the fuses, certainly. It would be entirely possible that the entire dashboard circuit is protected by a single fuse.
    I would like you to check if the turn signals are working when you activate them, even if the display does not light. With the car running, check to see if each and all of the turn signals are working even if the dashboard tells you nothing is happening. If they are working but your dashboard doesn't report that they are working, and if the fuses are all okay, then there is a design flaw going on. Maybe there is a BMW expert with some experience with this, if not on this site, but online.
  • edited July 2010
    I would look for a bad ground to the dash.
  • edited July 2010
    Check the fuses for any blown ones. If they are ok then the trouble may be with a loose connector to the dash panel.
