Join the Car Talk Community!
Discussion Rules
Sign In Register
2002 Honda Accord 6 disk CD changer
The FM and AM radio woks as does the tape player but when I select CD this message appears "Error".
<br/>
<br/> The changer is full but space one and two do not show up on the screen.
Comments
  • edited July 2009
    This is sort of a shot in the dark, but if you can disconnect the power to the unit for 30 seconds or so, when you reconnect it the unit might go through a reset process and clear up the confused state the changer is in. You can try disconnecting the fuses. Look at the fuse panel for them, there might be more than one. The other way to do this would be to disconnect the battery (only one cable) for about 30 seconds. I don't know that this will help you, but it has worked in my car.
