Winter tire size, very close
I am purchasing a '06 Saab 9-3 wagon, tire size 215-55-16.
I have winter tires from my previous car with lots of life left, size 215-60-16.
Can I get away with this size difference?
The only difference between the winter tires and the tires that are on the vehicle now is, the winter tires have a taller sidewall height of .42 inch. This might throw the speedometer off a couple of MPH’s.
It all depends on the vehicle you’re trading. The wheel might not even have the same bolt pattern as the new 9-3
Your speedometer will read slow by 3.34% no big deal.
This is the website I use when I’m looking for changing tire sizes, either similar or a + or - rim size:
I thought the OP was taking about tires…NOT wheels.
Seems I did misread about that. I was just assuming they had the tires mounted on separate rims
Thanks for the comments everyone. I do have just tires, and I will put them on.
