I have a 1999 Chevy Venture van. The driver side window will not go up. It goes down but not up. Passenger side works fine.
help!
Pull out the switch, clean the contacts with some electronics cleaner. Plug it back in and see what happens. You may also want to pull the door panel, clean & lube the regulator tracks & the contacts at the motor connection.
This might help.
