Wheels are stuck to the hubs.How can I get them off.
Put the lug nuts back on part way. Lower the vehicle to the ground. Push on the side of the vehicle so you get it osillating back and forth. If that doesn’t work, leave the lug nuts loose, and then go down the driveway and then slam on the brakes.
Loosen the lug nuts two turns. Go up and down the driveway a few times and hit the brakes. They should pop loose…
Thanks for the help!!
Thanks for the adivce
