Hi! I have a 2000 Nissan Frontier that is having issues. I had the distributor replaced and the knock sensor. The day I got it home it started having a weird starting issue. It has always started first crank super easy & strong. Runs GREAT.
When the truck is cool it starts right up but, when I’ve been driving around for a bit and turn it off, if it’s a short stop starts right back up, some hesitation. If I stop for 15-45 mins it doesn’t want to start. I can crank it all day and it wont start and gives a little kickback, if I crank too much the engine will smoke a bit, spits and sputters when you turn the key off. The longer it sits before I try to start it the worse it gets… around one hour is the worse. - Finally figured out if I try cranking it over several times, turn off the key and wait literally one to two minutes it starts right up super quick and strong just like when it’s cool. So random and weird.
No warning lights & Nothing shows up when hooked up to the computer, fuel pump checked out OK. PLEASE HELP! cant spend any more $$ on my ride : (
