I have a 2006 Nissan Frontier v6 4L 4x4
The truck ran great with no problems other then the fuel sending unit was bad so my gas guage was always wrong. I purchased a replacement sending unit and dropped the tank, removed the fuel pump, and finally replaced the bad fuel sending unit. My gas guage works now, but I noticed it took a few extra secods to start…it cranked and cranked…then finally started. This is not how is was before. I thought maybe it was due to fuel needing to run through the lines. I thought nothing of it and drove off.
Everywhere I parked…I always returned to extra cranking to get the car to start. A day later I decided to look for kinks in the lines. I thought I found one, so after dropping the tank, making sure everything was secure and routing the lines…i bolted it all back together…But now it won’t even start. The truck cranks and cranks, but there is no start. I was thinking of dropping the tank half way to make sure the electrical connector was on…outside of that I have no idea what to do, or what can be wrong.
