Does anyone here have firsthand experience on installing a Weber carb on a 84 B2ooo ?
I put one on an 86 Toyota. I’m guessing you are looking into a 32/36 DGEV. Its a pretty simple carburetor to work on, I would lower the float a little tough. Also, check your fuel pressure from your fuel pump. The Weber doesn’t like more that 5 psi or the needle wont seat and it will leak. If you have more pressure than that, you will need to either put on a regulator or order a viton needle. The viton needle will handle higher fuel pressure.
Thanks for your response.I noticed in my research that there might be a issue with the fuel pressure,I,ll have to check and see exactly how much is being pumped out.
