i see that it is impossible to remove the water pump on this car without some challenges. Do you need to remove the motor mount> jack it up> i would really appreciate the help if any one can help
thank you
Should stick to one post. But yeah the bracket and mount need to be removed. The stud in the bracket that bolts to the engine will need to be removed in order for the bracket to come off.
