Vehicle shakes
I have a 2003 corolla le and it vibrates when I drive.
I had the front end replaced, except sway bars, last year. Just had the front axles replaced and two new tires on front and still vibrates.
Any ideas?
Bent rims?
But take it back to the shop that did the work. Did they test drive it before returning the car to you?
How old are the struts?
Worn struts can cause tire bounce.
If you shift into neutral does the vibration go away?
I’m going to go out on a limb here–in other words I’m going to guess. If your car shakes and you’ve eliminated a problem in the front, i.e., wheels, tires, brake rotors, struts, half shafts, CV joints, etc., the trouble might be in the back. A rear wheel that’s out of balance or bent, or a bad rear tire, could still cause the whole car to shake.
