I am wondering what would a ball park figure/range for a dealer repair for the following:
Replace 4 rotors
Replace brake pads
(These are 18’s – performance tires/wheels)
Repair leak in transmission cooling line
Top off transmission fluid: 3 qts.
I had work done at my dealer – very pleased with it. Several people thought I overpaid. Just wondered what a dealer might charge for such a repair/parts. Thanks!
Olds Fan, Remind Us Again, What Are You Driving?
Also, the telephone can help you compare. Call around your local area. Give details. Get ball park estimates.
I’d be a little concerned with “topping-off” the transmission fluid with 3 quarts. Was it 3 quarts low? Rocketman
That Is More Than A “Top Off” Isn’t It?
Where’d it go? Oh, I see. The trans cooler line.
I could see this hitting $800-$1k. Why go to the dealer? Find a mom & pop mechanic they will have you back on the road for hundreds$ cheaper. Several people who thought you overpaid were right.
Even if you overpaid, now you have a relationship with your Dealer,now when something like a stuck plug comes up you will be treated fairly…right?
