Troubleshoot and repair
my 1995 dodge ram v8 has 96000 miles. It recently while driving the engine shuts down,no engine lights come on. after sitting for 10 to 15 minutes it will start and run again. a few minutes later it will do the same thing repeately
When it stops does it turn over,any lights in the dash,does headlights work?
My guess is key switch or under coating on hot wire has a lot of green crud,also check all connections red and black from battery.
it turns over and everything works. Someone suggested the fuel pump rely,Itried switching the rely out,still no luck,checked connections
