Trouble codes
code: po 303 and po 304 cylinder misfire detected on cylinder 3 and 4.
The history involves replacing the coil pack, spark plug wires and spark plugs. I am still having the trouble code and engine skip.
It is probably time to move to a fuel delivery problem. How you do that depends on the kind of FI you have, but a shop manual will likely be in order.
But before that I would suggest just checking the compression to rule out some kind of mechanical issue.
ok
