96 Eldorado Code 502( speed sensor fault ) Speedometer not working and vehicle running in low range. I replaced the speed sensor on the right side transaxil. No change, what else can I try?
Check the wiring from the speed sensor. If the wiring is bad the new sensor won’t make any difference.
