what is this item and how does it operate
Here is a description from ALLDATA…
The NV236 transfer case is an automatic transfer case with three drive ranges. Shifting from rear wheel drive to four wheel drive is done automatically when the transfer case shift control module receives wheel rotating slip information from the speed sensors. The transfer case shift control module then engages the transfer case motor/encoder to position the transfer case from rear to four wheel drive. When the transfer case shift control module receives information that the wheel rotation is the same on both axles, the transfer case shift control module sends position information to the motor/encoder to put the transfer case back into rear wheel drive. The three drive ranges are 2HI, 4HI, and 4LO. The 2HI position is for normal driving with the rear wheels pushing the vehicle. The 4HI, position is for driving through sand, snow, mud, gravel, or heavy rain at normal or slightly below normal speeds. The 4HI engages the front axle to allow for four wheel drive. The front axle is pulling the vehicle, and the rear axle is pushing the vehicle. The 4LO range is used for off road driving heavy snow, deep mud, or shallow fording. The 4io is similar to the 4HI except that the gearing in the transfer case is set for low speed and high torque. The NV236 is manufactured at Syracuse, New York by New Venture Gear a division of New Process Gear for General Motors.
