is the gas input tube seprate from the gastank? i’ve looked o.l at tanks and not one has a fuel tube.sorry had to reask evently I started typing before comp.was done loading
If you are talking about the tank fill tube, that is usually a separate item from the gas tank. It is connected by a short rubber coupling hose to the tank inlet fitting. The filler tube also has the vent tube attached which is also connected to the tank with an appropriately sized hose.
Hope that helps.
What year? Have you checked the boneyards?
trying no luck so far but info did help alot will try auto parts stores and ol places thank you !
