the pipe that connects from the gas tank to the car where i put the gas nosel in broke away. i have to use a funnel to put gas in my car. how can i easily fix this?
Broke away where ?
At the filler end ? If so, what’s broken ?
Or the tank end ? If it’s that end, you need a new gas tank. Full stop, the car should also be at a full stop until you fix it. It’s highly dangerous.
