I have a used tire going on a 20 wheel to be used only as a spare on a 2009 Venza. Can I use a regular valve stem or is it necessary to set the wheel as if it came from the factory ? thanks
If having the tps light doesn’t bother you ,go ahead.
thanks will do .
