I began the day trying to figure out where I was going to go for a second opinion and found a place called Mitchell’s Auto Repair. He popped up in Car Talk’s listings with extensive, thorough and good reviews (I know, this is how I ended up with the first guy, though on Yelp).
I gave him a call and explained the situation and he basically reiterated everything you have been saying to me, @ok4450 and @“common sense answer”. Then he said, as much as he’d love to do the work on it, the other guy should really take care of it and that I should go back, be aggressive and push him to do the right thing. Then he said that if I wanted to stop by his place on the way, he would show me the parts and how they all fit together so that I would know what to look for when I went to original shop! I was kind of amazed by this and enthusiastically accepted his offer since his place isn’t too far from the other. My boyfriend and I went to his shop and he showed us the different kinds of engines my car could possibly have and what they look like, in a book. Then he showed me actual pullies and a tensioner and how they look and sound in good shape and bad. He also showed me the tensioner casing and how it’s aluminum and that if a screw is overtorqued it can strip the aluminum, etc… He was a wealth of information with nothing to gain but good Samaratinship! He advised me as to how to speak with the other guys, to be firm and aggressive and to rest assured that they were in the wrong. (Oh! He also corroborated with you guys that the pothole theory is total BS!)
So then we set off to Alex’s (the bad guys!). I got there and my car was parked on the street out front. All the bits and pieces he had pulled out where tossed in the back of my car, along with anti-freeze spilling out all over my car’s interior. I was shocked! I lifted the radiator and all this anti freeze poured out of it. His reply? “We drained it but it doesn’t always drain out, that’s why we put papers underneath it”. By papers I think he was referring to random flyers and torn of pieces of paper back that were doing a very inferior job of soaking up the anti freeze. I just couldn’t believe it. My boyfriend quickly stopped it up with the paper towel I keep in the back. (why they couldn’t have done that is beyond me. The message: “we really don’t give a sh*@ about you or your car.”)
Then he shows me the broken bolt, which is indeed the bolt to the tensioner. Armed with information, I said that the pothole theory is BS and that the only way the bolt could have broken was if it was over torqued or too loose. He says there’s no way “his guys” overtorqued it, that they do these jobs all the time, they are pros they use a proper torquing wrench, that his shop is in no way at fault and chalks it up to it being an “old car”, shrug, shrug, shrug. (Of course when I brought it in for the first time and asked if the repairs I needed were worth it, he said it was a good solid car, blah, blah, blah) I say, “Okay, well…then I guess I’m taking you to court.” His attitude was just “do what you gotta do”. Totally unapologetic (and totally unapologetic about the antifreeze all over my car’s rear interior). His whole attitude was just like, “hey it happens”.
SO, I called Mitchell and told him what happened and asked if I could bring it to him for an assessment/second opinion and, of course, pay him for his time. We call the tow truck and bring it to him (a mere six blocks away!!). We bring it to him, he looks at everything (and advises me to take a picture of the antifreeze spilled all over, which I did!).
Assessment:
- The cross section of the bolt is totally even in color and texture indicating that the bolt itself was good.
- While the aluminum casing threads are not stripped, the bolt had to have been overtorqued.
- The pullies were never replaced and at least one of them is noisy and should have been replaced. The other is at least still smooth (so now I really want to know how only a timing belt, water pump, cam shaft seal and crank shaft seal kit with no pullies cost me $500)
- The valves on one side of the engine are most likely definitely damaged, but possibly still okay on the other side.
- It would be about a $2,000 repair or over.
- I have a case.
He also said he would park my car at the end of alternate side parking on a Tuesday side tomorrow so I would have some time to think about what I want to do. He said that with all the money I already paid on the maintenance repairs in the fall ($2400) to then spend another $2000+ on the engine repair might not be warranted by such an old car and that even if I junked it, I should still be able to sue the other mechanic to recoup all the money I gave him, but that I should take some time to think about it and he said he would write an assessment that I could use in small claims court.
When I asked how I could repay him…? He brushed it off and then made a joke about liking cookies. Well, Mitchell is in for quite a few batches, I can tell you that!
I’ll be heading to small claims court tomorrow and should have a court date within a few weeks! Meanwhile, I’m stashing the bolt away in a safe place and I’ve got lots of good pictures of the interior.
Eesh, what a day.
