Thick white smoke from exhaust
This smoke is not constant, no signs at the moment of a cracked block, or head gasket. Pcv valve cleaned, solenoid replaced
My crystal ball is in the shop…
I can read off the scanner that you have a 2012 Sonic but you posted essentially nothing about your car. Try adding some information if you want useful help.
