The poor state of manuals today
Here are some of the strange things I have encountered in computers, signs, manuals, and labels. The spelling errors are from the originals:
  • Keyboard not detected. Press F1 to continue.
  • Do not lose this radio in closet when installing dead batteries.
  • To be not this error, please accept the button change.
  • Carefully slip and fall into creek.
  • Small parts included for causing damage to children (Parcheesi game).
  • Be careful with the train (Translated standard Mexican railroad crossing sign).
  • Do not dispose direct to the sun.
  • Carefully respect the grass.
  • Bump handicapped pedestrians 5 mph.
  • Do not use the other cleaner, or the glass will become vague.
  • 10 ton bride ahead.
  • Caution! This end up when cup contains liquid.
  • Keep from wet where can injury electronics or customer and make lawsuit.
  • Private parking. All others will be toad.
  • When this sign is under water, the road is impassible.
  • Do not put low densy disk in high densy drive unless used in high densy drive.
  • Jumper 5: The options available are enable and disable (but what does it do?).
  • Reset all disturbed peripheral cards in motherboard sockey.
  • Please close all widows and try again. (huh??)
  • No trough traffic
  • If extension cord is needed, do not use.
  • Drit needed.
  • If colors are wrong, press RESET, and run program again. Repeat until correct.
  • The software must be reinstalled so the software can be installed.
  • If you hit this sign, you will hit that bridge.
  • Do not touch the light bulb when installing it.
  • Private sign. Do not read.
  • Open only at static free workstation (on a bag full of nuts and screws).
  • No use octopus to connect computer to wall.
  • Keep compuer well you from heat away, register, furness, radiator, TV, set, wok.
  • To keep legal, you put in register right away. Otherwise royalties come take you.
  • Dont try to tip TV cart on someone when moving.
  • Slow construction ahead
  • Use of this equipment subject to Federal Copyright Law. (Sign over a desk)
  • If lump not function, check plub, Then remediate bulb with other blub…
  • Sending chain mail through email is against policy. (What about plate armor?)
  • Find the I/O adress of the fuction, then setting jimpers j1 … j10.
  • If computer still not operate, problem is the computer chose is bad.
  • Product keep on shelf for reeks in pantly (not refrigerate).
  • This is nice mouse wash and prevents plague build-upon teeth.
Odd events:
  • An email saying university computers are Y2K compatible was dated 1/6/0100.
  • “Donkey Kong” was a mistranslation. It was supposed to be “Monkey Kong.”
That’s my philosophy
Not only that, but I believe it’s also stated in the handbook for commercial driver’s license
I would think it should be common sense for all drivers . . .
Car related OOH OOH, the dangers of dhmo, a component of antifreeze, washer fluid, vision issues while driving, loss of vehicle control, even a tablespoon can kill, here is the msds sds in the works I guess,
I got some new labels for ghs warnings, going to print them up tomorrow!
Good ones troubleshooter. Driving back today I was sure to keep the proper end of the coffee cup up, and checked all signs to see if they were under water.
Motorcycle helmets keep ME from paying taxes and increased hospital fees to support bodies that did not wear them “IRL.”
Put it in first gear. Release clutch. Engage starter. Drive on starter until clear of tracks.
Larry
With 100 bales of hay on the truck that starter might not be up to it Larry.
