Temperature know on dash after replaced heater core
1997 Buick Skylark V6 3.1Ltr
so a couple years ago the heater core went and it was bypassed at the firewall.
over the weekend i had it fixed and i bought the heater core.
now their is no heat plus temperature knob on the dash has some resistance and will rotate back a bit when turned and let go.
i took it back this morning before work and the guy says it may be the heater valve, but i do not think there is a heater valve in my car.
i say the air panels/diverters are not lined up right.
the heater core seems easy to install(well, once you take the dash apart).
it is only a mini radiator with two small pipes extending. it does not look like it is necessary to mess with any cables or flap/diverter doors.
any ideas/suggestions?
i just want to get some feedback because i am supposed to go back in saturday morning - maybe i shouldn’t. this guy is not going to want to go back under that dash. i may be better off finding someone else to fixe it.
thanks for any insight
