My 2003 VW Jetta TDI has a major problem. The engine has likely been damaged by an oil leak that was not discovered until the oil ran out. I now have much reduced compression (340lbs or less) and the car doesn’t like to start in cold weather and when it does it smokes much. I need to know if it is worth rebuilding and, if so, where I might have this work done. I live in the Chicago area. I may also consider purchasing a used engine and would like advice on how to get this done.
tdi_dan
1
This sounds like a duplicate message.
Related topics
| Tdi disaster | 3 | 540 | February 8, 2011 | |
| Diesel Landrover TDI jan 24, 2009 show | 0 | 274 | January 24, 2009 | |
| Fix it or sell it? | 4 | 512 | November 19, 2010 | |
| VW Jetta TDI | 16 | 2480 | November 26, 2012 | |
| VW beetle 2003 tdi compression leak | 2 | 511 | January 28, 2011 |
