TCM location-96 Dodge Intrepid
I have a code that is telling me there is no signal from the transmission control module or TCM. I want to inspect the wiring but I am not sure where it is located. The car is a 96 Dodge Intrepid with a 3.3L. Thanks in advance.
I only have a 97 Intrepid factory manual.
It says you have to loosen the battery hold down clamp and slide the battery to the right to access the “60 way retaining screw” holding the TCM connector.
Also, they show a TCM relay inside the Power Distribution Center under the hood. They show it in the corner closest to driver’s front.
Thanks,
I’ll look in those places.
I have a 96 Chiltons but it does not go into that type of detail.
I know the PCM is under the Air Intake box in the front right.
Thanks again.
No problem, happpy to help!
Let me know if you need anything. I love my 97 Intrepid that I’ve had for years. I’ve got the 3.5L, but the book covers both.
