I have a 2006 Honda element the taillights
stopped working it still has brake lights hazards, and blinkers. I’ve checked the bulbs and every fuse seeing how there isn’t a fuse marked as taillights. The only thing that has happened is a wreck but it was only slightly damaged on the front drivers side fender and the shop replaced everything that was damaged, so where would be a good place to start looking for this problem?
I’m Not Trying To Second Guess, But How Exactly Did You “Check” the Bulbs?
Also, does your Owner’s Manual have a diagram that better shows fuse locations? It seems like there would be a taillight fuse.
CSA
