Tail lights and interior lights went out
Hi
I have a 1988 Jeep comanche
I lost my tail lights, front marker lights and dash lights today
I have checked all the fuses under the dash and havent found any blown
I hooked a trailer up to it today and I think this is the cause
some how it caused a short
Can you tell me where to look for additional fuses
Thanks
I’ve had that happen when the trailer wiring had a short. It will be a fuse. Check your owners manual for fuse locations, you might have a fuse panel under the hood.
You need to check your fuses with an ohmmeter or a continuity light. They can blow with a hairline fracture that is difficult to see.
Thank you for the advice
I was able to find the problem
Do you know anything about windshield wiper problems
I have another post on the wiper problem I am having
Thanks
