Hi all:
Firts time in forum, hope to be around for some time.
Does anyone know the proper installation for a lower ball joint on a 1994 Subaru Legacy??
Raise and support the vehicle safely. Properly support the lower control arm assembly. Remove the cotter pin/castle nut from ball joint. Disconnect the ball joint from the lower control arm. Remove the bolt retaining the ball joint to the ball joint housing. Remove the ball joint.
