have a 1994 pontiac grand am. disc brake problem- rear left became tight after a short drive, i replaced the caliper and the problem returned. cracked the line loose- fluid was not under pressure. drove the car again, then the right rear brake tightened up (left was ok). disconnected park brake, no change. brakes release after 30 min rest. what is causing this???
Related topics
| Sticky rear drum brakes | 1 | 480 | September 20, 2008 | |
| Befuddled over Brakes | 4 | 727 | June 16, 2008 | |
| Brakes broke! | 6 | 1238 | December 5, 2011 | |
| Rear brakes keep locking up | 5 | 21863 | August 17, 2010 | |
| Brakes sticking after brake job? | 3 | 1785 | February 21, 2010 |
