Stiff Clutch
I think the stiff clutch on the high mileage Ford Ranger mentioned 6/16/2007 is due to a failing hydraulic line. Its collapsing from inside and blocked more when its hot.
When the clutch was previously replaced the old flexible line was damaged.
I just wanted to thank you for your feedback. Every bit of knowledge helps.
