Steering shaking
Recently,my car hit the curb on the left side. then my steering is shaking. it not that bad but it’s bothering me. what should i do to fix the problem? someone suggested me to do aligment. Could Guru help me to diagnose the problem please?
Look for a bent rim first.Put your spare on that wheel and see if it stops shaking, if not look for suspension damage.
First, I would have the wheel balanced. If it has a bent rim, they will find it. Then I would look at the alignment and for damaged suspension components.
Thank You sir, i will try it
You could have damaged the tire internally also.
