Stabilizer pin
HOW DO YOU REPLACE A FRONT STABILIZER PIN ON A 2002 FORD EXPLORER? THE ONE IN THERE NOW IS BROKEN
PHIL
Usually when a stabilizer bar end link has broken, it’s rusted to the point where the mounting hardware won’t budge. When that happens, it requires an oxy/acytelene torch or a high speed cut-off tool to remove the broken link.
otherwise, pretty simple. One long bolt, through the plastic sleeve with one nut ont the end.
