It always makes this sound when I first start and it is wet outside. After a few minutes the sound stops, presumably after whatever is squealing dries up. Ford dealership said this would cost $1200 to fix.
If anyone knows what this might be or how to fix it, please let me know. Thanks!
Drop the dealership and find a good independent mechanic. He will probably tell you that you need a new serpentine drive belt. The video was not a great help as the sound should have been recorded with the hood up.
Presumably the For Dealership you went to said more than just that it would cost $1200. What, exactly, were they planning to do for that $1200? That’s about 10 times the cost of replacing the serpentine belt.
