I believe it is along a seam.  Years ago I used “Barsleak” and it worked very well in a 1974 Plymouth. This car ia s Honda 1995 Accord. Would you recommend it in a newer car?
 I enjoy your talk radio program.  Thank you.
I would not recommend it because your car is old enough to need a new radiator. If a seam is leaking, it will just expand and leak again. If you see green or white coloring on the radiator, it’s usually time to change it, leaking or not.
Bars-Leaks is a good product, it will work for a while, and it won’t hurt anything…Replacing the radiator is not as big a deal as your may think…Try radiators.com to get a pricing idea…
