Should my F-150 be smoking after head replacement?
I have a 2016 Ford F-150 2.7 with 25000 miles. Ford just replaced both heads because it would smoke the first time you would start it for the day. I got it home and the next two morning when I first started it I still had smoke. I called and they said this is normal and should stop in about a week. Does this sound right?
No, it does not sound right. Wait a week, watch for smoke, if it goes away, the dealer was right. If it doesn’t the piston rings may need replacing, the turbo’s oil seal may need replacing or a few other things. And BOY is that low miles for ANY of that to happen!
